03 Ultra blowing oil through filter - Harley Davidson Forums: Harley Davidson Motorcycle Forum
 4Likes
post #1 of 16 (permalink) Old 06-01-2019, 03:02 AM Thread Starter
Hi, have recently replaced stock cams with the S&S cam drive kit, original cam backplate & pump, S&S adjustable pushrod. It runs excellent but every now and then it blows oil out of the filter housing, especially if we go highway riding. Where have I gone wrong? And what would be the fix? In advance thanks!
Ole H is offline
post #2 of 16 (permalink) Old 06-01-2019, 06:55 AM
South GA Redneck
baggerboy's Avatar
What your oil pressure?
baggerboy is online now
post #3 of 16 (permalink) Old 06-01-2019, 09:18 AM
SCHMIDTY's Avatar
Those could be your problem.
How many miles on the engine ?
Did the lifters get replaced ?
SCHMIDTY is online now
post #4 of 16 (permalink) Old 06-01-2019, 05:26 PM Thread Starter
Forgive my late reply, oil pressure is about 35 at Idle, 45 - 50 at 3000 rpm
Ole H is offline
post #5 of 16 (permalink) Old 06-01-2019, 05:32 PM Thread Starter
Yes, replaced lifters with the new ones from the S&S 510G Gear Drive Cams kit
Ole H is offline
post #6 of 16 (permalink) Old 06-01-2019, 06:00 PM
SCHMIDTY's Avatar
So ... how many miles on your engine ???
post #7 of 16 (permalink) Old 06-01-2019, 07:52 PM Thread Starter
Has been changed speedometer a couple of times, but a qualified guess would be just about 100 000 miles
Ole H is offline
post #8 of 16 (permalink) Old 06-02-2019, 07:28 AM
SCHMIDTY's Avatar
By those numbers I'm thinking the cam plate relief valve could be stuck.
baggerboy and tommytailspin like this.
post #9 of 16 (permalink) Old 06-02-2019, 09:08 AM
Sounds like a stuck relief valve. Those oil pressures, at least idle are high.
2005FXD likes this.
bobf is online now
post #10 of 16 (permalink) Old 06-02-2019, 10:14 AM
JLR
JLR's Avatar
The relief valve bleeds off pressure at the high end - shouldn't effect idle pressure. You might want to verify the pressure with a mechanical gauge.
Jim
2007 FLHTCUSE2
S.E. 10.5:1 pistons, S.E. 251 cams, S.E. pro tuner
Big Sucker ll, Rinehart True Duals
1977 Triumph Bonneville Silver Jubilee - sold after 40 great years together
As I've grown older, I've learned that pleasing everyone is impossible, but pissing everyone off is a piece of cake.
JLR is online now
