Faulty oil filter?? - Harley Davidson Forums: Harley Davidson Motorcycle Forum
 10Likes
  • 1 Post By Thunder~Struck
  • 2 Post By EvoRK
  • 5 Post By Chriscraft
  • 2 Post By Breeze3at
post #1 of 10 (permalink) Old 07-14-2019, 11:55 AM Thread Starter
Chriscraft's Avatar
Faulty oil filter??
Hello, New to the forum. (Thanks for accepting)
Just completed an oil change on a 06 Ultra I recently picked up. Used a HiFlo HF 171C, Using Brad Penn 20W-50 partially synthetic.
My question is, after running the bike for 15 minutes , oil pressure dropped to 0, bike started lugging. No leaks, oil level fine. oil light came on,
pulled over trailered bike home.
Has anyone heard of new filters failing? My first time using HiFlo Filters.
Any suggestions or advice appreciated.
Chriscraft is offline
post #2 of 10 (permalink) Old 07-14-2019, 12:02 PM
SCHMIDTY's Avatar
HI Canada ! Question, was the engine running good before you did the service ?
SCHMIDTY is offline
post #3 of 10 (permalink) Old 07-14-2019, 02:05 PM
Mississippi Cajun
kd5cqt's Avatar
I wouldn't go pointing fingers at the filter for dropping OP to zero, but perhaps a problem with the oil pump?
USAF Veteran, PGR Member, Retired Old Fart! 2015 Electraglide Ultra Limited
Hey, immigrants: Learning English and assimilation to American culture is NOT a suggestion!
kd5cqt is online now
post #4 of 10 (permalink) Old 07-14-2019, 04:50 PM Thread Starter
Chriscraft's Avatar
absolutely, engine was 100%, just seemed too coincidental for pressure to drop right after oil change. Just installed new K&N filter & no difference. Going to check sending unit wires, and follow up with pressure gauge if necessary
post #5 of 10 (permalink) Old 07-14-2019, 04:54 PM
Asylum Inmate
bbally's Avatar
If it went as last time where you had pressure and then it went to zero.
Crankcase is not breathing correctly
Sent from my SM-N960U using Tapatalk
USMC Sgt 79-85
Malo periculosam, libertatem quam quietam servitutem
Western Colorado PGR
2003 VRSCA
2016 FLTRXS
AMA PAC Supporter
bbally is online now
post #6 of 10 (permalink) Old 07-14-2019, 05:21 PM
Wayward Son
Thunder~Struck's Avatar
FWIW
Synthetic blends are a waste of $$.
Has been proven to have no benefit over fossil.
We now return you to the original reason for your posting.
Originally Posted by Chriscraft View Post
.....Going to check sending unit wiresb, and follow up with pressure gauge if necessary.....
Would say since the drop and lugging corresponded, it is working.
uncas likes this.
You`ve been
Thunder⚡️Struck
ATW
1L/TWF
🇺🇸 R.E.D.
People are why I love Dogs and my Harley.
💔In Loving Memory💔
❣️Thor❣️
09-08-17
🐾No longer by my side. Forever in my heart.🐾
🖤Bear, Brute, Jessie James, Billy the Kid, Aiyana🖤
ROLO
04-03-14 > 07-27-16
Ed
11-20-17
Bee
No such thing as just a Dog.
Thunder~Struck is offline
post #7 of 10 (permalink) Old 07-14-2019, 07:40 PM
06 Ultra spring cam chain tensioner may have given up the ghost and took out the oil pump. Wouldn’t be the first one
tommytailspin and tekslk like this.
EvoRK is online now
post #8 of 10 (permalink) Old 07-18-2019, 07:47 PM
Glasspilot's Avatar
EvoRK, good guess. If the bike sat for months or years and you suddenly start it maybe a cam shoe that was on the edge might just go. Time to take the "points" cover off and do the check.
My Ultra's a 2006 also, I did the SE hyd kit a few years ago. You gotta do it!
2006 EG Ultra Classic
1975 Suzuki GT750
2017 Chevy Volt
Glasspilot is offline
post #9 of 10 (permalink) Old 08-18-2019, 09:15 PM Thread Starter
Chriscraft's Avatar
Thanks again for the advice/experience
Turns out it was a cam bearing, took a chunk from oil pump. Just weird it happened at precise moment I changed oil.
So tore it down, did screaming eagle cam plate/hydraulic tensioners, fueling cams, 95" big bore kit, Ness air box, Reinhardt true duals. My cheap buy, ain't so cheap anymore. But it certainly moves better when ya twist on it 😎
post #10 of 10 (permalink) Old 08-19-2019, 07:17 AM
Breeze3at's Avatar
Thank you for coming back with the cause of the problem!
Colt.45 and Smoketown$1 like this.
I ride like an old guy that wants to get older.
Pete / Breeze .380
Breeze3at is online now
