Multimeter Recommendations . . . - Page 3 - Harley Davidson Forums: Harley Davidson Motorcycle Forum
 27Likes
post #21 of 41 (permalink) Old 04-15-2018, 11:51 AM
Negative Ghost Rider
I have a fluke as I use it for putting money in my pocket.
As said, most meters sold at the big box stores will do everything the average homeowner/ shade tree will need.
~ Humphrey Bogart
misinlink is offline
post #22 of 41 (permalink) Old 04-15-2018, 12:11 PM
SCHMIDTY's Avatar
Originally Posted by DRVMN View Post
Thanks Everyone . . . Just found, and purchased this one off of eBay.
https://www.ebay.com/itm/Klein-MM300...vip=true&rt=nc
The same model was $30 at Home Depot. I already have a circuit tester so I just purchased the meter.
Now when ya get it read the instructions dude ! Those instructions can teach ya some 'electronics for dummies' stuff!
SCHMIDTY is online now
post #23 of 41 (permalink) Old 04-15-2018, 12:16 PM
Breeze3at's Avatar
I have let the smoke out of several quality and a couple of multimeters. I get dyslexic with the dial setting and poof! I have a couple of Harbor Freight freebies, and a decent Craftsman that still have smoke in them. I also have a 20 yr. old Radio Shack credit card size meter with the original battery in my saddlebag.
Kainam likes this.
I ride like an old guy that wants to get older.
Pete / Breeze .380
Breeze3at is online now
post #24 of 41 (permalink) Old 04-15-2018, 12:28 PM
SCHMIDTY's Avatar
The trick is NEVER test amps, the meters are only good for 10 and the Harleys have 5, 10, 15, 20, 40 and 50 amp circuits ! Use an amp clamp meter for that. Most multimeters do test milliamps tho.
SoftailBilly likes this.
post #25 of 41 (permalink) Old 04-15-2018, 01:28 PM
Kainam's Avatar
Images: 150
Does anyone test for milliAmps on automotive/motorcycles?
Mala Ipsa Nova
Psalm 144:1 Luke 22:36
'05 Carbed Night Train
111 rwhp, 112 rwtq
Best 1/4 ET 12.557s
Best 1/4 MPH 108.59
http://weathersticker.wunderground.c...ansas_City.gif
Kainam is online now
post #26 of 41 (permalink) Old 04-15-2018, 02:06 PM
Poser Member # 99
big john@dog's Avatar
Images: 5
This will work for sure . good choice
this is the one that I have and use the Most and it's a Tenma
post #27 of 41 (permalink) Old 04-16-2018, 09:21 PM
SoftailBilly's Avatar
Use to look for excessive draw on battery when power is off. Most ECMs will draw small amount power. In milliVolts . Be about it I think.
Stay Vertical
USAF Veteran, Patriot Guard Rider.
2009 Softail Custom in Vivid Black, 3"Slip ons, SE A/C Kit, Knight Rider Xieds, SE Compensator, Fork Brace and some more chrome to polish.
SoftailBilly is online now
post #28 of 41 (permalink) Old 04-17-2018, 06:21 AM
Super Moderator
ematicic's Avatar
Images: 9
One fun meter suggestion, careful when checking for resistance. Many people new to a meter might not realize that to test resistance, the meter must send voltage. When I worked on helos we had some noobs check for resistance on the wrong things and if checking wrong on solid state, even with small volts from meter, it was possible to smoke something. Not sure if Harley components are as sensitive but just be aware.
"Men can only be highly civilized while other men, inevitably less civilized, are there to guard them" - George Orwell
ematicic is online now
post #29 of 41 (permalink) Old 04-17-2018, 07:39 AM
SCHMIDTY's Avatar
The best test for determining parasitic battery discharge (ignition off).
post #30 of 41 (permalink) Old 04-18-2018, 03:15 AM
Outlaw
Doc M's Avatar
I agree, that one should work just fine and give you years of use. One small suggestion, it probably has a cheap Chinese battery in it, replace that with a quality battery before it starts leaking and kills the meter. Other than that you should be good to go.
As for what batteries I use, been using the Duracell copper for decades, buy a fresh box every December and replace all of the batteries in everything, smoke alarms, clocks, meters whatever January 1st whether it needs it or not. Look for bulk pack deals if you use as many as I do. There's probably even better batteries out there, that one is just my choice as I have yet to have a problem with them.
FLYING TIGER and JLR like this.
I want to die in my sleep like my grandfather, not yelling and screaming like the passengers in his car.
When I was a child, I thought nap time was punishment.
Now it's like a mini-vacation.
What doesn't kill you sometimes make you stronger,
and sometimes it just pisses you off!!
Doc M is offline
