Legend Suspension Heads up - Harley Davidson Forums: Harley Davidson Motorcycle Forum
 9Likes
  • 5 Post By loubob
  • 1 Post By loubob
  • 3 Post By loubob
post #1 of 9 (permalink) Old 11-18-2018, 08:44 AM Thread Starter
loubob's Avatar
Hey everyone, just thought I'd give you all a heads up on my suspension change. I went with Legend after lots of research and reviews and talking to dealer techs all over the country when I travelled for work. The bike is a 2014 Electra Glide Ultra. I went with the standard height rear Revo-A's and could not be happier. They are so far superior to the OEM air junk. Super easy preload adjustment (turn the spring) and an adjustable rebound lets you dial these babies in for your loads, though I find that once set up for the Tour Pack and riding two up, I'm very happy when I Take the Tour Pack off and ride solo too.
Now for the front. Installed Standard height Axeo's NOT the lowered ones. The ride is exceptional, stability and handling improved noticeably, AHHH but the downside NOT explained by anyone in writing or otherwise. You lose about 1.5-2 inches of height up front. I am dragging my jiffy stand riding like I always did and it didn't use to drag. I'm talking about round-abouts and normal corners, not riding the Tail of the Dragon (which I guess I'd better avoid now) I thought I was just being a touch more aggressive due to the ride improvement until I did my 50K oil change. I couldn't get the oil pan I have always used under the bike. Then Looked at the slider covers and the bottom of it was down on the pin stripe line instead of level with the top of the fender like they used to be. I called Legend and texted back and forth several times and they basically told me there was nothing they could or would do because it was normal. They explained their SAG is different then the OEM to get their ride quality. I'm pissed that I lost lean angle, especially since it does ride and handle so much better.
I spent way to much to change them out to something else and since the ride is amazing I'm gonna live with it, Just thought anyone considering the Axeo front suspension from Legend ought to know what they are going to experience.
peanut, ematicic, cloondog and 2 others like this.
Blessed beyond measure.
Honored to be a PGR member.
loubob is online now
post #2 of 9 (permalink) Old 11-22-2018, 08:08 PM
zeero's Avatar
Hi Loubob, interesting to hear of your experience. I've got the standard Revo rear shocks and standard Axeo installed earlier this year on my '13 Ultra. Awesome ride now and I didn't lose any clearance, maybe it's something with the Rushmore setup. Hope you can get it worked out.
Sent from my iPad using Tapatalk
-Zeero
zeero is offline
post #3 of 9 (permalink) Old 11-22-2018, 08:27 PM
Senior Flatulant
Smoketown$1's Avatar
I have not yet had a new front end apart.
How much room/travel do you have before you're 'spring bound'?
Do you have room for 1-1/2 or 2 inch spring spacers? (Old school chopper days ... )
Cheers,
Smoketown
Smoketown$1 is online now
post #4 of 9 (permalink) Old 11-23-2018, 07:10 AM Thread Starter
loubob's Avatar
Cheers,
Smoketown
The new parts don't accept spacers, the preload is set by turning a set ring. I asked about tightening it a couple more turns but the ride stiffness will increase to an undesirable level they told me, and only gain a small amount of height.
Kainam likes this.
post #5 of 9 (permalink) Old 01-04-2019, 09:45 PM Thread Starter
loubob's Avatar
Follow UP
So I finally decided to have the Forks taken apart again and measure the suspension. I have been in touch with Legend back and forth for months. The guy I'm emailing finally said this was the only way to know if I had the right parts. He told me to give him certain dimensions and they would tell me if the parts I got were what I ordered.
I responded with NO, you give me the dimensions of the standard and the lowered parts, which he sent to me. Today I found out that I got a set of 1" lowered in a standard height Box. The label part number was correct but what was ion the box was not! The Battle is on. Legend is closed on Fridays. My Dealer and I both contacted them via email. I expect a replacement set of suspension parts and the fork oil and for them to absorb the labor cost to do this disassembly check and the replacement. Since I ordered them through my dealer, they are on my side on this deal. I will update.
The ride truly is WAY better, and now, knowing I've got the lowered parts and once that is back to standard, I'll get my lean angles back, I'll sing their praises. I'm guessing a Production Packaging Quality control issue caused this. Sucks for me but I hope they make it right.
scspartan, zeero and JLR like this.
post #6 of 9 (permalink) Old 01-05-2019, 06:18 AM
Most Wanted
confederate's Avatar
Images: 17
Perhaps it would be best to let the dealer handle this since the parts were ordered through them. It's a business transaction, keep it that way and don't make it personal. Remember, you catch more bees with honey.
FXDC
SEPST*HP 81.26*TQ 88.49*Stage 1*Rinehart Exhaust*Ness Big Sucker*External Breathers*FL Air Cleaner*Leatherpros FXDXT Bags*Moons MC Moonmaker*Saddlemen Step Up Seat*Windvest*Mobil 1 V Twin 20w50*Amsoil V Twin Primary Fluid*Amsoil V Twin Transmission Fluid
Hades02
That's like not f...ing your woman so that the p*ssy stays fresh and new for the next guy.
FTW
All posts self censored for the hypocrites
confederate is offline
post #7 of 9 (permalink) Old 01-05-2019, 06:31 AM
The dealer should make it right..... let them fight it out on the other end with the supplier.
2013 Ultra Classic
Midnight Pearl/Brilliant Silver Pearl
SE Race Tuner, SE Ventilator AC
RC Component Mufflers
Fullsac Head Pipe
Dyno tuned
jpassh2o is online now
post #8 of 9 (permalink) Old 03-11-2019, 10:59 PM
zeero's Avatar
Well??? How does the story end?!
Sent from my SM-G930T using Tapatalk
-Zeero
zeero is offline
post #9 of 9 (permalink) Old 03-15-2019, 12:43 PM
glust's Avatar
Lou, I'm interested in this topic. I am not sure if you or anyone else would know the answer to my question, but I have a set of JRI's on the rear of my '14 limited. Absolutely love them. Stock parts on the front. My question is: would the legends upfront work well with my JRI's on the rear or would I need to change everything over to the LEGEND product line? The ride is already good and you kind of sold me with your noticeable difference with the LEGENDS on the front.
"Once in a while you get shown the light, in the strangest of places if you look at it right.." Robert Hunter
glust is online now
Similar Threads
Legend Revo-A Suspension Upgrade rjfunk Touring General Discussions 8 01-17-2016 08:59 PM
Legend Air Suspension fatboy71 Suspension 1 08-24-2012 06:49 PM
Legend Air Suspension Group Buy jhillier14 VRSC General Discussions 0 08-22-2011 08:17 AM
Going to port my own heads. Which OE Evo heads should I use? phelan Performance 5 07-21-2009 05:06 PM
Are 883 heads and 1200 heads the same Zeta7 Sportster General Discussions 1 09-26-2008 10:02 PM
