Remove battery acid stains from primary cover? - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 7 (permalink) Old 04-23-2011, 06:44 PM Thread Starter
Anyone know how to or even if it's possible to remove battery acid stains from a primary and clutch cover. My wife bought a 96 sportster 1200 and the stains were already there. I'm pretty sure they're aluminum. Doesn't seem like the acid pitted the metal too much. Anyone ever have luck with this?
HOG_WILD_STEVE is offline
post #2 of 7 (permalink) Old 04-24-2011, 01:24 AM
mrmetal's Avatar
I would try aluminum polish if it doesn't seem to be petted. If it is a little pitted lightly sand it with some 600 wet dry sandpaper and then polish with aluminum polish. I've used some mothers polish that worked really well.
mrmetal is offline
post #3 of 7 (permalink) Old 04-24-2011, 05:26 PM Thread Starter
I tried the mother's aluminum polish last night. Seemed to work a little. The areas that are really bad probably won't get much better but I'm going to pick up one of the mothers power cone polishers to try it. Save my hands the cramping and I'm sure it'll do better than by hand.
I'd love to try to sand it but since I've never sanded metal before I'm worried that I'll make it worse.
post #4 of 7 (permalink) Old 04-24-2011, 05:39 PM
2000 grit wet sand paper with WD40 as cutter. Polish afterwards with Mothers or similar polish.
R.I.P. Rubberdown. 1971-2012
2005 E.G. Classic
S&S 510 cams
Baisley Oil pump spring
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #5 of 7 (permalink) Old 04-24-2011, 07:29 PM
As Dave said,2000 grit with WD40 will speed up the process and won't hurt a thing. Rub it out with rubbing compound and then polish. Polishing alone may not get the job done and takes forever.
Dee Jay is offline
post #6 of 7 (permalink) Old 04-26-2011, 01:49 PM Thread Starter
What kind of rubbing compound?
post #7 of 7 (permalink) Old 04-30-2011, 06:41 PM
EVO RULER
moose49's Avatar
I like dupont #7 for polish compound
*CONFORMITY IS JUST A SLOW FORM OF SUICIDE*
******SUPPORT YOUR LOCAL INVADERS*******
********RIP RUBBERDOWN RIDE FREE********
moose49 is offline
Similar Threads
How to remove the primary cover off your Sportster XL1200R Sportster General Discussions 28 09-11-2018 02:00 PM
Acid core solder squeekie Electrical 20 05-05-2013 12:11 PM
