Primary Outer Cover Removal - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 6 (permalink) Old 04-17-2017, 10:15 AM Thread Starter
Has anyone ever seen this before? I bought a 89 883 Hugger. I recently changed oil, oil filter, air filter, spark plugs, and I want to change the primary oil but I've not seen a cover like this on another bike. Is there a special tool? Any advise would help. Thanks
Jd77 is offline
post #2 of 6 (permalink) Old 04-17-2017, 10:25 AM
Frozen Member
naknekpete's Avatar
Probably, but it would be a specialty tool just for that. It looks like the smaller cover on the left has a slightly bunged edge from the tool used to tighten it. You should easily be able to make something like a big screwdriver from a piece of flat stock.
naknekpete is online now
post #3 of 6 (permalink) Old 04-17-2017, 10:33 AM
SCHMIDTY's Avatar
Yep, it's called a "Chevron" and Harley, aftermarket and others sell the tool. I use a chisel to knock it loose !
SCHMIDTY is offline
post #4 of 6 (permalink) Old 04-17-2017, 10:39 AM Thread Starter
Is it threaded?
Jd77 is offline
post #5 of 6 (permalink) Old 04-17-2017, 10:53 AM Thread Starter
Are the threaded on there? And thanks for the help.
Jd77 is offline
post #6 of 6 (permalink) Old 04-17-2017, 11:05 AM
SCHMIDTY's Avatar
Yep, it's threaded ... unscrews in the normal direction too ! Use a blunt object in the groove and tap it with a hammer to the LEFT to loosen, to the RIGHT to re-install.
With the blunt tool at the top, not the middle ! Top left to loosen.
SCHMIDTY is offline
