Engine issues? - Harley Davidson Forums: Harley Davidson Motorcycle Forum
 2Likes
post #1 of 28 (permalink) Old 05-12-2019, 10:57 PM Thread Starter
Engine issues?
I picked up a 2012 Iron 883 with 22k miles on it, and my dad when he picked it up for me because I was at work put 87 in it and it kind of was running rough and seemed like it almost wanted to die sometimes if you came to a stop in 1st and left the clutch in, so I ran the bike almost completely empty and then put 93 in it, but ive noticed sometimes while im just holding throttle in 1st or 2nd all of a sudden the revs will kind of dip and then they'll kick up and the bike will jerk almost as if I've downshifted when I haven't, and it just seems to run a bit boggy and choppy sometimes, would this be still because of the gas? Could it be the throttle cables? Any tips or info would greatly help, this is my first bike and my first harley.
oPiruz is offline
post #2 of 28 (permalink) Old 05-12-2019, 11:18 PM
Kainam's Avatar
Images: 150
Your bike has EFI. Use some carb cleaner in the throttle body, in particular the IAC port at the top of the intake.
Mala Ipsa Nova
Psalm 144:1 Luke 22:36
'05 Carbed Night Train
111 rwhp, 112 rwtq
Best 1/4 ET 12.557s
Best 1/4 MPH 108.59
http://weathersticker.wunderground.c...ansas_City.gif
Kainam is online now
post #3 of 28 (permalink) Old 05-12-2019, 11:57 PM Thread Starter
Will try and report back, thank you for the info/tip
oPiruz is offline
post #4 of 28 (permalink) Old 05-13-2019, 12:37 AM
Colt.45's Avatar
OPiruz
After you do like Kainam says start running a few ounces [ 6-8 oz.] of Sea Foam through it every month.That should keep everything cleaned out from then on.
Colt.45
"You are never out of the Fight"
2008 Rocker..traded for a 2015 Road King traded in for a .. 2019 Iron 1200
U.S.A.F. 75-79
Colt.45 is online now
post #5 of 28 (permalink) Old 05-19-2019, 03:51 PM Thread Starter
So I tried the intake cleaner and it didnt do much, the bike especially after a slight blip of the throttle and letting it idle back down will sound kind of bogged like it wants to die and then i'll hear a kind of "pff" or something along those lines, basically kind of sounds like when you detach an air hose from a fitting, just not as loud or aggressive, I tried cleaning the throttle body with the bike running and not (including that little IAC hole), the filter looks almost brand new no holes no dirt no clogs etc. Could it be a bad throttle? Or maybe the cables need to be adjusted? The biggest problem I have with this is it did it once while i was in the middle of a sharp parking lot uturn and almost made me drop the bike, and then as I was attempting to accelerate uphill out of a parking lot into traffic it did it again and the bike almost tipped and hesitated, if it does that while im trying to pull out into 60 mph traffic im as good as a hood ornament
oPiruz is offline
post #6 of 28 (permalink) Old 05-19-2019, 05:30 PM
JLR
JLR's Avatar
What has been done to this new to you sportster? It might need a tuner if exhaust and intake were changed Have you put new spark plugs in yet? It just might cure your problem, especially if it has been run on old gas.
Just throwing some suggestions out for you to check out.
Jim
2007 FLHTCUSE2
S.E. 10.5:1 pistons, S.E. 251 cams, S.E. pro tuner
Big Sucker ll, Rinehart True Duals
1977 Triumph Bonneville Silver Jubilee - sold after 40 great years together
As I've grown older, I've learned that pleasing everyone is impossible, but pissing everyone off is a piece of cake.
JLR is online now
post #7 of 28 (permalink) Old 05-19-2019, 06:33 PM
Hit it she goes boom
GotGold's Avatar
Put some Seafoam in the tank, ride her like ya stole her, see if something changes.
"Our lady of blessed acceleration don't fail me now."--- Elwood Blues
"What does not kill you makes you stronger..... except for bears, bears will kill you."
"Give her full throttle till ya see God... then back off"--- Some guy in a bar.
GotGold is offline
post #8 of 28 (permalink) Old 05-19-2019, 08:21 PM
SoftailBilly's Avatar
Said you cleaned the IAC hole. Look into top area of throttle body and key the switch on and off. You will see the pintle pull all the way up and come back down. When pintle is pulling up spray carb cleaner into open hole. Do it few times. Black soot will drain out. Engine will take a bit to start, only air is suppose to enter into passage way.
Stay Vertical
USAF Veteran, Patriot Guard Rider.
2009 Softail Custom in Vivid Black, 3"Slip ons, SE A/C Kit, Knight Rider Xieds, SE Compensator, Fork Brace and some more chrome to polish.
SoftailBilly is online now
post #9 of 28 (permalink) Old 05-19-2019, 09:41 PM Thread Starter
The bike is bone stock aside from the paint job and a set of cheap slip on python mufflers. I haven't tried spark plugs yet which would be a good idea.
oPiruz is offline
post #10 of 28 (permalink) Old 05-19-2019, 09:42 PM Thread Starter
I will try this tomorrow after work and report back.
SoftailBilly likes this.
oPiruz is offline
Similar Threads
engine cut off issues mwelch General Motorcycle Related 3 07-01-2016 09:36 PM
Possible Engine Issues XL1200R Sportster General Discussions 27 08-09-2013 09:19 AM
Ignition issues issues on a evo to twincam conversion. Pikey Electrical 3 06-17-2013 09:38 AM
Shovelhead Engine Case VIN issues... Please help!!! Jabbo Classics General Discussions 2 09-25-2011 05:18 PM
