2006 883R Tachometer RPM - Harley Davidson Forums: Harley Davidson Motorcycle Forum
 8Likes
post #1 of 30 (permalink) Old 08-18-2019, 04:29 PM Thread Starter
45auto's Avatar
I just added an aftermarket tachometer to my Sportster and I'm only getting 1500 RPMs at 50 miles an hour 5th gear, is that right? Idles at 500.
45Auto
45auto is offline
post #2 of 30 (permalink) Old 08-18-2019, 04:49 PM
Senior Flatulant
Smoketown$1's Avatar
Sounds like it may be 'mis-set'.
On many tachometers, there a switch, screw or jumper to adjust for the number of cylinders. (1 cyl., 2 cyl., 3 cyl., 4 cyl., etc.)
You may have to remove the housing to get to it.
Cheers,
Smoketown
2003 FXST & 2013 CVO Ultra
Smoketown$1 is online now
post #3 of 30 (permalink) Old 08-18-2019, 06:38 PM
Kainam's Avatar
Images: 150
^^^ Yup, its only giving a reading of half the RPM
Mala Ipsa Nova
Psalm 144:1 Luke 22:36
'05 Carbed Night Train
111 rwhp, 112 rwtq
Best 1/4 ET 12.557s
Best 1/4 MPH 108.59
http://weathersticker.wunderground.c...ansas_City.gif
Kainam is online now
post #4 of 30 (permalink) Old 08-19-2019, 06:37 AM
Is the tach, made for Harley's? If so what years? Early Harleys are dual fire,( both plus fire at the same time) newer ones fire each plug separately. Check the years your tach is made for.
bobf is offline
post #5 of 30 (permalink) Old 08-19-2019, 10:19 PM Thread Starter
45auto's Avatar
I found out it is a single fire ignition have to buy a separate adapter that runs both of the coil wires together into one..
WTF how about make a motorcycle tach that works on all types 1cyl to 8cyl
False advertising.
45Auto
45auto is offline
post #6 of 30 (permalink) Old 08-20-2019, 07:31 AM
Some tach do work on all combinations, but it's up to the user to buy the correct one, or to set the set the switch to the correct setting.
Smoketown$1 likes this.
bobf is offline
post #7 of 30 (permalink) Old 08-20-2019, 11:19 PM Thread Starter
45auto's Avatar
He had s list of what it worked on. My bike was listed. Guess im a dumbass for believing the written word. My bad.
45Auto
45auto is offline
post #8 of 30 (permalink) Old 08-23-2019, 02:26 AM
Why
Why do you need a tacho anyway?
rogerpaul is offline
post #9 of 30 (permalink) Old 08-23-2019, 08:28 PM
Senior Flatulant
Back in the day, I bought a large chrome Sun tach with a metal housing for one of my cars.
The catalog listed all of the American autos it worked on.
When I received it, the instructions had an alphabetical list of cars followed by the 'adapter' number needed to make it work.
Danged adapter to make it work cost more than the tach did.
Sent it back.
I didn't read the fine print.
Cheers,
Smoketown
SoftailBilly likes this.
post #10 of 30 (permalink) Old 08-25-2019, 12:03 AM Thread Starter
45auto's Avatar
Ok got it figured out. I have a single fire coil & have to combine front & rear signals together using a adapter rig.
Made the adapter rig they showed of a resistor & diode on each cylinder signal wire & all together to tach green. Idling around 900 now. Much better but will check it for accuracy.
Kainam and SCHMIDTY like this.
45Auto
45auto is offline
