No spark 91 sporty - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 11 (permalink) Old 10-24-2019, 10:13 PM Thread Starter
Mr614's Avatar
No spark 91 sporty
Thoughts on what i am missing or need to get spark? The picture is how i have bike wired new ignition switch, starter and plug wires. The motor turns over but wont fire.
Mr614 is offline
post #2 of 11 (permalink) Old 10-25-2019, 03:55 PM
Super Moderator
ematicic's Avatar
Images: 9
Fuel?
"Men can only be highly civilized while other men, inevitably less civilized, are there to guard them" - George Orwell
ematicic is offline
post #3 of 11 (permalink) Old 10-26-2019, 08:46 AM
SCHMIDTY's Avatar
Is the light flashing on the ignition module when cranking the engine ?
SCHMIDTY is offline
post #4 of 11 (permalink) Old 10-26-2019, 04:43 PM Thread Starter
Mr614's Avatar
Yes it has fuel and the light on ignition module is on when ignition is on and flashes when i push start button. I thought it was a timing issue so tried to set to tdc per service manual and adjust per crane cam manual. Crane cam manual says light should go off when you turn clockwise, never turned off so maybe its not true tdc?
Mr614 is offline
post #5 of 11 (permalink) Old 10-26-2019, 05:34 PM
Have you checked to see if there is spark at the plugs? remember you will need to have both plugs connected to see spark.
bobf is online now
post #6 of 11 (permalink) Old 10-26-2019, 06:58 PM Thread Starter
Mr614's Avatar
I grounded plug on head and got nothing.
Mr614 is offline
post #7 of 11 (permalink) Old 10-26-2019, 07:30 PM
Do you have aftermarket ignition or stock?
EvoRK is online now
post #8 of 11 (permalink) Old 10-26-2019, 11:57 PM Thread Starter
Mr614's Avatar
Crane cam
Mr614 is offline
post #9 of 11 (permalink) Old 10-27-2019, 09:20 AM
SCHMIDTY's Avatar
Is the Hi-4 set to single or dual fire ? Also is the coil correct for the application ?
SCHMIDTY is offline
post #10 of 11 (permalink) Old 10-27-2019, 04:49 PM Thread Starter
Mr614's Avatar
It is high 4 single fire
Mr614 is offline
