2002 Harley DTC's - Page 2 - Harley Davidson Forums: Harley Davidson Motorcycle Forum
 5Likes
post #11 of 26 (permalink) Old 07-02-2019, 01:51 PM Thread Starter
norm9278's Avatar
Originally Posted by baggerboy View Post
Is it still throwing the CKP code? Next step is to reset codes and try starting bike with a know good CKP sensor to see if it clears the problem. Also make sure you have performed the wiggle test to make sure you have ruled out intermittents. I have an 03 RK in shop right now with the same problem. Since I dont have a known good sensor, I ordered on that will be in this afternoon. The CKP sensor can give all kinds of problems and sometimes not even send a code. Short of you having some wiring or ecm issues, I would say you have a bad CKP sensor.
Dunno if it's still setting the code. Don't know how to clear them on this bike (02 RK). I did find out that it wasn't a missing hose. It was a missing vacuum plug. Fixed that! Seems to start quicker. Could that missing vacuum plug set those codes?
Sent from my coal fired bag phone using Tapatalk
norm9278 is online now
post #12 of 26 (permalink) Old 07-02-2019, 01:58 PM
South GA Redneck
baggerboy's Avatar
2002 Harley DTC's
You cant clear them when you use the speedo to pull the codes. But if the codes are current the CEL will come on and stay on, you have to remove the test wire from the diagnostic port before cranking bike. That rubber plug shouldnt cause the CKP sensor to be throwing any codes.
edited for spelling errors
baggerboy is offline
post #13 of 26 (permalink) Old 07-02-2019, 02:37 PM Thread Starter
norm9278's Avatar
Yeah, I removed the jumper right after I read the codes.
Just took it around the block for a check ride. CEL on at key on. Goes off after engine starts. 10 mile ride and no CEL, much less decell popping. I'm calling it fixed, unless of course it isn't...maybe there was a bad connection that got cleaned up by all the pulling and pushing?
I'll get back after I can run it a bit more.
baggerboy likes this.
post #14 of 26 (permalink) Old 07-02-2019, 02:40 PM
South GA Redneck
baggerboy's Avatar
Good news. Hopefully you got it. I never wouldve thought that rubber plug would cause that. But hey learning every day. Just keep that ol CKP sensor in the back of your head should it show itself again.
post #15 of 26 (permalink) Old 07-03-2019, 01:53 PM Thread Starter
norm9278's Avatar
I'm not convinced that the missing plug was the whole problem either, but time will tell. I also found a couple of spots on the horn wiring harness where mice had been chewing. Tank is full of fuel now so that'll have to wait till I get some burned off to check the harness underneath. What I can see by blocking up the rear looks ok.
Thanks for your assist, I owe you a beer if you ever get up this way!
post #16 of 26 (permalink) Old 07-03-2019, 02:44 PM
South GA Redneck
baggerboy's Avatar
Mice can definitely do some damage! Thanks for the beer offer. Will definitely keep that one in mind!
post #17 of 26 (permalink) Old 07-06-2019, 02:45 PM Thread Starter
norm9278's Avatar
We'll, I was right about that...it ain't fixed. Started it this morning and the damn CEL came on again. On a brighter note, my service manual finally arrived.
post #18 of 26 (permalink) Old 07-29-2019, 07:17 AM Thread Starter
norm9278's Avatar
Just to update for anyone who might research this in the future.
It turns out that you can not clear the DTC's on these older bikes unless you have the HD computer scanner Gizmo, which I don't. After completing the repair the DTC becomes a " historic" code, which is identified by the CEL going off at startup, then coming back on for 8 seconds before turning off again. This occurs for the following 30 ignition cycles. Important piece of info there that I didn't have.
Anyway, to shorten a long story the problem turned out to be a broken wire. At the starter B+ post there is the battery cable and a smaller wire that feeds the main circuit breaker. That smaller wire was broken off of the terminal and making intermittent contact, which apparently threw the codes. Rode 150 miles Sunday with no issues
baggerboy and JLR like this.
post #19 of 26 (permalink) Old 07-29-2019, 07:30 AM
SCHMIDTY's Avatar
FYI that small wire is the B+ feed from the regulator.
SCHMIDTY is offline
post #20 of 26 (permalink) Old 07-29-2019, 07:40 AM
South GA Redneck
baggerboy's Avatar
Good catch. And after having this issue a couple of times on bikes, its something I check pretty often now. It will definitely make you scratch your head trying to figure it out!!! IMHO that connector at the battery terminal gets abused during battery maintenance and is often times twisted while torquing battery connections. That cant be good for it in the long run.
