Electrical help needed, lights - Harley Davidson Forums: Harley Davidson Motorcycle Forum
 10Likes
  • 3 Post By Thunder~Struck
  • 2 Post By Dan89flstc
  • 2 Post By Notorious
  • 3 Post By tekslk
post #1 of 8 (permalink) Old 08-08-2019, 11:47 PM Thread Starter
Behind Enemy Lines
Notorious's Avatar
I have a 2003 EGC and one of the front signals doesn't light up when the bike is on. The turn signal will work and flash when activated, but the light doesn't turn on and stay on. The other turn signal stays on and flashes when activated.
Could it be a fuse? It's always on a tender and the battery is pretty new.
Thanks for any insight.
Notorious is offline
post #2 of 8 (permalink) Old 08-08-2019, 11:49 PM
Wayward Son
Thunder~Struck's Avatar
Have you tried swapping the bulbs?
gtrman66, Smoketown$1 and Ddaddyo like this.
You`ve been
Thunder⚡️Struck
ATW
1L/TWF
🇺🇸 R.E.D.
People are why I love Dogs and my Harley.
💔In Loving Memory💔
❣️Thor❣️
09-08-17
🐾No longer by my side. Forever in my heart.🐾
🖤Bear, Brute, Jessie James, Billy the Kid, Aiyana🖤
ROLO
04-03-14 > 07-27-16
Ed
11-20-17
Bee
No such thing as just a Dog.
Thunder~Struck is offline
post #3 of 8 (permalink) Old 08-09-2019, 06:42 AM
SCHMIDTY's Avatar
No not a fuse or the other lights wouldn't work either. Like said swap the bulbs or just get a new one at the auto parts store or Walmart if you're feeling brave !
SCHMIDTY is offline
post #4 of 8 (permalink) Old 08-09-2019, 03:15 PM Thread Starter
Behind Enemy Lines
Notorious's Avatar
Are there 2 bulbs in there?
The turn signal light is solid yellow and on all the time when the bike is running, then it'll blink when I activate the turn signal.
Now one is off and the other one is on when the bike is running. But both work fine when I activate each turn signal and blink. So I know the bulb still works, but it doesn't turn on and stay on when the bike is running.
post #5 of 8 (permalink) Old 08-09-2019, 03:20 PM
Dan89flstc's Avatar
The bulb has two filaments, one for turn signal and one for running light.
gtrman66 and SCHMIDTY like this.
1989 FLSTC
2016 FLHR
2019 FLHTI
Dan89flstc is online now
post #6 of 8 (permalink) Old 08-09-2019, 03:28 PM Thread Starter
Behind Enemy Lines
Notorious's Avatar
There you go, problem solved!
Thank you sir.
gtrman66 and 1/2 Ton like this.
post #7 of 8 (permalink) Old 08-09-2019, 07:45 PM
tekslk's Avatar
Oh Boy.
Kainam, SCHMIDTY and Smoketown$1 like this.
tekslk is online now
post #8 of 8 (permalink) Old 08-16-2019, 08:17 AM
If it is an 1157 (typical running/turn signal bulb) the little protrusions on the side of the bulb base which engage the slots in the socket are at different heights from the bottom of the base. The socket slots are at different heights also, so the bulb will only go in one way. Be sure to match the positions or you won't be able to latch the bulb into the socket.
btsom is offline
