Electrical - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 5 (permalink) Old 09-02-2019, 10:20 AM Thread Starter
Electrical
Hello everyone, I have a question maybe someone could help. I have a 03 electra anniversary with the 88 engine. Stator been replaced battery and regulator and still very little charge at idle. On the open road I get 14-16 volts charge, but at idle I get no more than 10 volts which trigger the engine light. Also I'm getting oil in regulator plug. Any ideas to what's going on???
Chubb006 is online now
post #2 of 5 (permalink) Old 09-02-2019, 12:16 PM
Proud Infidel
Alan S's Avatar
What's your idle speed?
Oil in the plug means you don't have a good seal. Should have put some black silicone around the plug for insurance when you installed the stator.
Sent from here to there.
What is freedom of expression? Without the freedom to offend, it ceases to exist.
Salman Rushdie
Alan S is online now
post #3 of 5 (permalink) Old 09-02-2019, 12:38 PM
Guitar NOT Gator
gtrman66's Avatar
Did the '03 have engine codes?
Are you sure you have a good ground for the regulator?
Have you double checked you don't have a connection to ground from the stator? Did you replace the rotor? Could have been a chunk of magnet still floating around in there and tore up your new stator (ground test should confirm).
2016 Ultra Limited
2004 Softail Springer
1993 Dyna Low Rider
1983 FLHT
200,000 HOG Miles
IBA Member since 3/31/12
Proud member of the NTC (North Texas Crew)
http://www.ravenswaymusic.com - the new band!
http://www.doolinband.com - the old band!
Dr. Rick "Superman" Doolin 1970-2014. Miss you bro.
gtrman66 is online now
post #4 of 5 (permalink) Old Today, 08:02 AM Thread Starter
No...I didn't put any silicone around the plug. I will remember that from now on. My idle speed is around 8.5-9k rpm. Sitting at a red light my voltage meter reads about 10volts..not charging. There are no codes due to the bike charging at high rpm. At about 70-80 mph the bike charges 14-16 volts. I will re-check the regulator ground. Did a test with fluke to check stator...its good.
post #5 of 5 (permalink) Old Today, 08:19 AM
JLR
JLR's Avatar
You must mean 8.5 to 9 hundred RPMs. My Ultra doesn't charge at idle either. With a permanent magnet alternator I wouldn't expect it to.
Jim
2007 FLHTCUSE2
S.E. 10.5:1 pistons, S.E. 251 cams, S.E. pro tuner
Big Sucker ll, Rinehart True Duals
1977 Triumph Bonneville Silver Jubilee - sold after 40 great years together
As I've grown older, I've learned that pleasing everyone is impossible, but pissing everyone off is a piece of cake.
JLR is online now
