Clutch problem. - Harley Davidson Forums: Harley Davidson Motorcycle Forum
 2Likes
  • 1 Post By Gallows
  • 1 Post By Alan S
post #1 of 4 (permalink) Old 08-30-2019, 07:01 PM Thread Starter
Clutch problem.
1986 Fxr Super Glide with 5 speed Tranny, dog leg style.
What it does: After adjusting the clutch it will run about 80 miles then clutch lever gets loose and very hard to shift when not moving. Then very hard to shift while moving.
What we’ve done: Has new Barnett clutch cable. Inner clutch hub had a broken bolt in it so we installed a new one. Clutch hub nut then began spinning loose so we used high temp red lock tight to set it. Clutch hub seems still tight. Throw out bearing was crushed, so changed it, still good. Large C-clip popped loose, was wore on one side so we flipped it and set it.
The exact problem persist. Outside of putting a bullet in her (So temping) I’m open to any knowledge. Thanks guys.
Gallows is offline
post #2 of 4 (permalink) Old 08-30-2019, 07:20 PM Thread Starter
Can’t delete this post but seems the C-Clip is pushing out. Will get a new one and save a few bullets.
Kainam likes this.
Gallows is offline
post #3 of 4 (permalink) Old 08-30-2019, 09:20 PM
Proud Infidel
Alan S's Avatar
Glad you got it figured out.
Even more glad you shared.
Sent from here to there.
Gallows likes this.
What is freedom of expression? Without the freedom to offend, it ceases to exist.
Salman Rushdie
Alan S is online now
post #4 of 4 (permalink) Old 09-03-2019, 12:22 PM
South GA Redneck
baggerboy's Avatar
Originally Posted by Gallows View Post
Cant delete this post but seems the C-Clip is pushing out. Will get a new one and save a few bullets.
It is easy to bend/warp that large snap ring when removing it.
baggerboy is online now
