Rear Wheel Bearing Blowout. - Page 5 - Harley Davidson Forums: Harley Davidson Motorcycle Forum
 17Likes
post #41 of 44 (permalink) Old 08-30-2019, 12:51 PM
JLR
JLR's Avatar
Maybe the rear brake was dragging. The resulting heat ruined the bearing and the dragging brake ruined the rotor??
candyman1340 likes this.
Jim
2007 FLHTCUSE2
S.E. 10.5:1 pistons, S.E. 251 cams, S.E. pro tuner
Big Sucker ll, Rinehart True Duals
1977 Triumph Bonneville Silver Jubilee - sold after 40 great years together
As I've grown older, I've learned that pleasing everyone is impossible, but pissing everyone off is a piece of cake.
JLR is online now
post #42 of 44 (permalink) Old 08-30-2019, 01:57 PM
South GA Redneck
baggerboy's Avatar
If the OP means that by going out he means that the balls came out of the bearing completely, I would assume the axle would be loosely floating around in the hub causing the rotor to possibly get warped???
baggerboy is online now
post #43 of 44 (permalink) Old 08-30-2019, 02:07 PM
SoftailBilly's Avatar
When a ball bearing starts going south. Excessive play would begin as the balls come out of cages or lose their spacing along inner and outer races.. Some movement should have been felt by rider on smaller bike. Bearing going into total destruct mode likely from over loading or lack of lube.
Stay Vertical
USAF Veteran, Patriot Guard Rider.
2009 Softail Custom in Vivid Black, 3"Slip ons, SE A/C Kit, Knight Rider Xieds, SE Compensator, Fork Brace and some more chrome to polish.
SoftailBilly is online now
post #44 of 44 (permalink) Old 09-09-2019, 12:07 PM
Grease needle adapter for sealed bearings which do not require you to remove the seal...
https://www.amazon.com/s?k=grease+ne...l_2srzickvol_p
Parts left off don't wear out.
rocky53204 is online now
Similar Threads
DNA Mammoth Rear Wheel Bearing Failure at 2k miles in. RichieD Wheels and Tires 15 04-10-2016 09:48 AM
Rear wheel bearing issues BendWeasel Wheels and Tires 2 11-09-2015 04:11 PM
Ever had a spoke wheel blowout? igya Sportster General Discussions 9 09-10-2014 09:04 PM
rear wheel bearing tlg1100 Softail General Discussions 2 08-19-2011 05:30 PM
rim split causing blowout Bill Brunson Suspension 6 10-31-2008 10:03 PM
