2016 Harley Heritage Rear tire stem valve question - Harley Davidson Forums: Harley Davidson Motorcycle Forum
 14Likes
post #1 of 25 (permalink) Old 08-12-2019, 10:46 AM Thread Starter
LateNight
kansast's Avatar
have a 2016 Harley Heritage , with only 2,000 miles on it. Air leaking out of the rear tire via the base of the stem valve. I am assuming I need to get the rear stem valve replaced. Going to attempt to do this myself. I've seen others jacking up the bike, and using a vice to break the bead on a tire to gain access to the stem valve. Is there any reason why I wouldn't want to try this ? Curious if there's anything I should be aware of or careful of or a reason not to try this myself. It being the back the tire.
kansast is online now
post #2 of 25 (permalink) Old 08-12-2019, 11:23 AM
DRVMN's Avatar
I believe (but could be wrong) that if your rear wheel has spokes - going off of the picture you shared in your introduction post, that it would have an innertube and not just a valve stem.
2016 Harley-Davidson Ultra Limited
-10" Wind Splitter Windshield
-Tour-Pak Passenger Armrests
-Harley-Davidson Rider Backrest
2016 Harley-Davidson Forty-Eight (Wife's Motorcycle)
-15" Quick Release Windshield
-Single-Sided Swingarm Bag
-Tribal Footpegs, Grips, Mirrors
DRVMN is online now
post #3 of 25 (permalink) Old 08-12-2019, 01:29 PM Thread Starter
LateNight
kansast's Avatar
If I'm to believe what I'm reading in other threads on this forum. This particular model 2014 Harley Heritage is of a number of models that although have spokes, does in fact have a tubeless tire. Something about a liner is in place, that is recommended to be replaced with each tire change. Which all brings me back to my original question. if the trouble on this tire is just the Valve Stem, is replacement of this valve stem possible. Via the ways I've seen online, breaking the seal of the tire to the rim, gaining access to the back of the stem valve, removing it and replacing it.
post #4 of 25 (permalink) Old 08-12-2019, 07:21 PM
Senior Flatulant
Smoketown$1's Avatar
You won't know if you don't try ... Worst-case scenario, you have a tube and off comes the wheel assembly.
I like using a couple of boards and C-clamps to break the beads. Less localized stress on the sidewalls.
Sawzall, if I'm scrapping the tire.
Cheers,
Smoketown
kansast likes this.
2003 FXST & 2013 CVO Ultra
Smoketown$1 is online now
post #5 of 25 (permalink) Old 08-13-2019, 06:17 AM
Breeze3at's Avatar
It can probably be done. But all things considered, removing the rear wheel to do it sounds less frustrating and quicker. Just think of all that wiggling around in the prone position, lack of room to get your hands/tools on the wheel. Please let us know what you do, and how it turns out.
I ride like an old guy that wants to get older.
Pete / Breeze .380
Breeze3at is online now
post #6 of 25 (permalink) Old 08-13-2019, 06:23 AM
SCHMIDTY's Avatar
Those spoked rims require tubes even tho the tire is tubeless.
SCHMIDTY is online now
post #7 of 25 (permalink) Old 08-13-2019, 09:17 AM Thread Starter
LateNight
kansast's Avatar
found elsewhere in these forums. waiting on my new air compressor to come in and my new Stem valve. Then I'm gonna give it a shot.
post #8 of 25 (permalink) Old 08-13-2019, 09:21 AM Thread Starter
LateNight
kansast's Avatar
Cheers,
Smoketown
Thanks for the tip. I've seen some youtube vids doing the same, gonna give that a try.
post #9 of 25 (permalink) Old 08-13-2019, 09:50 AM
Guitar NOT Gator
gtrman66's Avatar
Is your rim stamped "MTM Tubeless"?
2016 Ultra Limited
2004 Softail Springer
1993 Dyna Low Rider
1983 FLHT
200,000 HOG Miles
IBA Member since 3/31/12
Proud member of the NTC (North Texas Crew)
http://www.ravenswaymusic.com - the new band!
http://www.doolinband.com - the old band!
Dr. Rick "Superman" Doolin 1970-2014. Miss you bro.
gtrman66 is offline
post #10 of 25 (permalink) Old 08-13-2019, 04:02 PM
Frozen Member
naknekpete's Avatar
Are you sure its not just a leaking valve core?
tommytailspin likes this.
naknekpete is offline
