In the Technical electrical section, just read down the list to the post that refers to FOBs. Assigning a new FOB.Hmmm, that sounds fun! I guess I’ll work on getting a fob. You said the procedure to pair a new one is on this website? I’m new to these forum pages lol
I guess this would probably be the best first optionThere is another option, you can transport your bike to a Harley Dealership and have the service dept connect their Digital Tech shop computer to run some diagnostics to determine the cause of the failure.
ill throw the battery on it and see if it gets any higher. Thanks for the input!10.7 volts on a battery while trying to start the bike sounds like a bad battery. Put a charger on it overnight and see what it does.
Okay, I guess ill work on finding a key fob. I assume I cant just get any Harley fob. Here one I found on ebay...In the Technical electrical section, just read down the list to the post that refers to FOBs. Assigning a new FOB.
A used FOB has been programmed with a different bike, I'm not sure it can be re-programmed to a different bike.I guess this would probably be the best first option
Okay, I was wondering about that. I’ll work on finding a new one. I’ll call Harley and see if I can get one from them. Thank you sir!A used FOB has been programmed with a different bike, I'm not sure it can be re-programmed to a different bike.
The instructions outline programming a NEW FOB not a used FOB. FOB p/n is 68926-00*
The guy I bought it from said he lost the fob but he said he never needed it. I am thinking maybe the battery got low on voltage. When I was trying to start up the bike originally it died pretty quick from cranking it and i had to try and jump it. So that is probably the reason.There's one thing that's not mentioned in the instructions and I don't recall if the security system needs to be off to assign a new FOB. Then it would need a trip to the dealer but either way a new FOB will be needed.
It would be interesting to know why your bike got into the security mode.
Have you searched over your bike to verify the FOB isn't hidden someplace ? If it is and the FOB battery went dead that may have set the security system and could explain the red key light. I would check the bike over with a fine tooth comb.
In that case you'll need a new FOB programmed to your security system. But you might need a trip to the H-D dealer to get things setup on their shop computer. I'm thinking the security system needs to be off prior to programming the new FOB. Find a new FOB and go from there, I'll be looking for ya too. Looks to be an obsolete p/n but could still be available. If ya get one new battery for it right away.The guy I bought it from said he lost the fob but he said he never needed it. I am thinking maybe the battery got low on voltage. When I was trying to start up the bike originally it died pretty quick from cranking it and i had to try and jump it. So that is probably the reason.
I just found a new one still in the package on ebay. I went ahead and ordered it. I called harley and they said I should be able to program it myself. So once that comes in ill go from there and keep you updated. Thank you for all the time you have put in helping me!In that case you'll need a new FOB programmed to your security system. But you might need a trip to the H-D dealer to get things setup on their shop computer. I'm thinking the security system needs to be off prior to programming the new FOB. Find a new FOB and go from there, I'll be looking for ya too. Looks to be an obsolete p/n but could still be available. If ya get one new battery for it right away.
The Harley security system is very secure for a reason and not simple to defeat.
Okay, I will be very thorough with it. If for some reason I can not get it then I will take it to my local harley dealer and have them do itBe careful ! Read all the instructions. It ain't that easy ! Ya just can't go out and buy a part to defeat the Harley security system. That FOB needs to be programmed to your security system that appears to be active right now. Your bike is trying to not be stolen right now. I know these systems and I'm betting on your bike !
No, with no FOB and no pin you ain't getting in !Isn't there a process that you can go thru to bypass the security system? I know I have to go thru some turn signal presses and such if I lose my fob or it goes dead. I was also able to program in my own numeric code for disabling the security system. It will let you start the bike but if you turn it off, you have to go thru the same process again. Also, if the former owner didn't assign a custom code number, I think I found a video on youtube some yrs ago on doing it with a factory default code.
I know you need the pin. My fob battery went dead a few yrs ago on my 09' ultra. I was able to find a video that showed me how to bypass my alarm using the factory default pin. I was lucky as the former owner of my bike had never changed the factory pin number. I was able to bypass the system and start my bike without my fob. Since then, I have changed the pin and wrote down the steps for bypassing the security system. I keep it on me now. "IF" the factory default pin has not been changed, you can bypass without the fob. The harley default is 31313No, with no FOB and no pin you ain't getting in !
