1 - 3 of 3 Posts
Had a acquaintance bring me his bike to figure out what is wrong with it. Here's what Ive got so far. He tried to wire in some radio and he tried to splice rt into the Igniton key switch 3 wire. He said he heard a pop. I checked fuses and they are all ok. Here's the deal. Turn key on to Acc and speedo lights up then turn to The On position and Everything goes out. Like lose power in On position. I think ignition controls module is fried . Anyone have a ignition electrical flow chart ? Or any Ideas it would be greatly appreciated.
Almost got to be a fuse, or the switch itself. Have you tried measuring across the switch(with it disconnected) using ah ohm meter ? Ignition module would not cause the problem you are having
I would take a close look at the wiring that he connected to the switch.. He didn't just happen to put the ground wire from the radio into the run position on the switch? Ensure all newly added wiring is disconnected, then see what happens... Just my 0.02
Reactions: WiSeNhEiMeR
1 - 3 of 3 Posts
