06 Electra glide backfiring on acceleration/ loss of power at 3k
1693 Views 10 Replies 7 Participants Last post by  EvoRK
I recently installed a screaming eagle stage III kit into my 06 Electra glide. Everything runs great at idle but as soon as the bike is under power it bogs down and back fires on easy acceleration. This occurs in any gear and from what I can tell at around 3k. If I hammer the throttle through 3k it runs fine. I replaced the TPS sensor, new plugs, new coil since it started.
Can anyone offer some help?
1 - 11 of 11 Posts
What tuner do you have?
doesn't have a tuner on it....down loaded the program from a pc down loaded into the ecm.
OP installed a stage 3 in his Glide in his garage by hisself ? I'm not amazed that it isn't working as planned ! Waiting to see what the OP does to resolve this situation !
Off the top...easy thing first. Go back and adjust the push rods.Are you positive you did the install properly?
If you downloaded a map from a pc there must be some type of tuning software that allows you to do this.
In addition to the software, check for hardware issues such as intake or exhaust leaks.
I'm thinking he did not do a full Stage III.
But did d/l and install the Stage III map.
Now we wait......
replaced cams, larger pistons, rollers, cylinders, springs etc. We used a programmer to download the map into the ECM (dyno jet power vision)
Also changed the air intake and turned into a true dual exhaust (cobra) with Vance and Hines slip-ons
That rules out this.....sorta.
v v v v v v v
Now we wait......
Get it properly dyno tuned before you ruin it
Reactions: 2
1 - 11 of 11 Posts
