Ok, so I went and bought a Quadzilla fairing and I'm in the process of installing it and need a little help.
The instructions indicate that one of the wiring cable connectors needs to be installed in the Ignition Controlled Lead under the seat. I've pulled the seat and the battery and am pretty sure I found the correct Deutsch connector that this single pin connector connects to. The problem I'm having is that the Hoppe instruction says to connect the pin to the Orange wire that has a white strip. Well, there's a red with a yellow strip, a solid orange, an orange with red strip and a black wire. No orange with a white strip. Eh, no biggie I'm thinking as I used to wire FA-18s for a living while in the Navy, how hard could this be. Well, after spending an hour going through the wiring diagram and online search I've narrowed it down to the two orange wires, but am still not sure which one to use.
Don't want to fry something by accident so I'm looking for a little help. Best as I can tell this is the power lead for the radio and the proper pin will shut it down when the bike is off. I don't want to fry anything, so I don't want to play by trying one or the other, so I'm looking for a little help. Anyone have an idea of which orange lead to use? Solid orange, or orange with red strip?
Thanks!!!
Thanks!!!
