1 - 7 of 7 Posts
I HAVE A 07 STREET GLIDE AND AM GETTING CRANK CASE OIL BLOW BY THROUGH THE CARB… ANYONE KNOW OF A FIX FOR THIS PROBLEM? I AM GETTING TIRED OF CLEANING OIL OFF THE RIGHT SIDE OF MY MOTOR AND FRAME AFTER A NICE RIDE. :Thanks
Road Glide
07 with a carb ? no carbs in Europe since 05. As SGHWD said check your oil level when hot. I set mine to 3/4 of the way up.
1.) No carb, EFI.
2.) Check oil level.
3.) If traveling speeds over 70-75, crankcase venting from heads will appear from the aircleaner cover, by design. Not abnormal. Not a great design. There are better aircleaner housings out there with better venting designs to prevent this.
Another solution is to get the breather hoses from the Screaming Eagle AC kit and install them. This routes the oil from the breathers into the efi to be burned.
1 - 7 of 7 Posts
