1 - 16 of 16 Posts
made 132.81 HP/127.32 TQ with the new set up
Discussion Starter · #2 ·
107" 10.3 or 10.5 to 1 not sure till see invoice CP Pistons, bigger valves, bronze guides, fully ported stock cyl heads, 50mm SE throttle body, S&S gear drive set up, S&S easy start 635HO cams, still have the TTS master tune, SE tapered push rods, SE heavy breather, Took rinehart true duals off for a D&D boarzilla 2 into 1 pipe
Dirty Member
You Bastard - OK only joking.
I have a 107" and did not end up with those numbers, but I am still working on it. Congradulations dude-good job.
Very nice, do you have the dyno to share? How does the throttle respond/ hit in the low to mid torque range?
Stock or worked over crank?
Timken?
Discussion Starter · #7 ·
stock crank I have the dyno sheet will try to download today
it makes 109 ft/lbs at 2600 rpm so it should pull awesome not picking it up till next tues
Reactions: Jake
Sounds nice! I'm doing my 103 kinda similar to your 107. 10.5 compression, S&S 625 easy start gear drive and ported and polished heads. I also have the TTS tuner. Dyno on original 103 before build was 70 hp and 102 torque. Can't wait to get it back.
Discussion Starter · #10 ·
you should check out the new HO series S&S has, the 635 matches power of the 640 but with more low end torque which makes it a much better street cam. lobe separation is much tighter down to almost 100
The Angry One
Damn. Those are big numbers. Congrats!!
Discussion Starter · #14 ·
it was around 5k with the D&D boarzilla at 850 and the ghost pipe being 300
Discussion Starter · #15 ·
and I never corrected myself on the pistons, the CP pistons are 11:1 cr
Discussion Starter · #16 ·
my dyno sheet
the as delivered was with woods tw-555 cams TTS tuner Rinehart true duals and a SE heavy breather
Reactions: naknekpete
1 - 16 of 16 Posts
