1 - 3 of 3 Posts
If you watch CAI Mag you'll recognize this post. I'm looking for some guidance on removing installing the fuel inlet fitting on my 81 FXS (OEM 27371-76). The part is a 90 degree plastic/steel combination part installed by a press fit into the carb body. With no obvious points to grip for a pull or access to push out, I could use some experienced advice on how to proceed. Finally, based on the OEM part failing, I'm considering changing to one of the all metal high-flow or swivel replacements; any thoughts/feedback appreciated.
Thanks all - ride safe.
1 - 3 of 3 Posts
