1 - 6 of 6 Posts
Been stored for 20 years, and I'm thinking of buying it. I assume I'd have to replace oil and fuel lines, but anything I should check or be wary of? Thanks.
The Extreme Member
Seals, Gaskets, clean out Carb... If your getting a good price (LOW) then it might be worth it.
Get ready to spend some money my friend. If it is what you want go for it. :cheers
Kicking Rocks...
Tires, battery....
Shine a light in the gas tank. It could be rusted and/or have tar that used to be gas. Remove and clean, petcock too. Brakes need to be flushed (DOT5, purple stuff). When dealing with the seller take the "it's been neglected for 20 years position" not the "it's only got xxx miles on it".
Be alive!
Full check of all ..
Good luck
1 - 6 of 6 Posts
