1 - 2 of 2 Posts
Tail light and brake light stay on all the time even when the bike is completey turned off. Have to remove bulb in order not to drain the battery. Could it be a specific relay or switch that is stuck. Any help would be appreciated for the location of this problem.
Thank you,
John
Discussion Starter #2
Took seat off. LIghting circuit wiring was rubbing against the positive battery terminal (fried a small hole in casing)which caused the tail light to stay on all the time. Yeah, very weird. All set now. Thank you again.
1 - 2 of 2 Posts
