hello, i bought a sportster '99 looked up the vin# it tells me that it is a 883 custom. the title has as a 1200. any way to tell if was converted into a 1200. the engine block vin matches the bike vin. i was told it had some engine work done but they didnt know what. it has a little bit of a oil leak and form what i can tell, kits will work on a 883 and 1200.
part two.vacuum line under carb. first pic the small line off the brass 90 elbow going down. where should that go? it is not plugged into anything.
thanks for any help you can give.
