Spending a bunch of money on a hydraulic master cylinder and using the same heavy clutch springs, may result in a disappointment if you frequently get caught in traffic
Well, I'm kinda caught between a rock and a hard place.
I do get caught in traffic, like every day. But I also can feel my clutch slip some
if I run it hard and shift at redline, so there's no possibility of going to lighter springs.
I'd bet your RC had 3x the clutch spring pressure my LowRider has, I'm not sure what the increase was when they put in the 95 inch kit, it's not the SE race clutch, I think one extra plate maybe?
Anyway, with 1550 cc kit, no cam, no head work, no nitrous, nothing extra, I think the book says I'm at 91 ft/lbs TQ and who knows what HP certainly less, so I'm not really needing a real high performance clutch, but I wouldn't think going down in pressure any is an option either. Anyway, with a 25% discount going on, the parts to do the hydraulic conversion were around $500, maybe I'll find somebody who wants a chromed cable op'd tranny cover and help me recover some $$. There was something annoying to my technical purist side to have that cable actuated clutch, anyway.
At the same time, I bought one of the last few of the 2008 "slipper" clutches Max had at the time for the V-Rod, now that's going to be a supremely sweet deal there. Technically excellent.
I'm far from having the sport bike rider need that my son has, about down- shifting hard into corners, so far as I'm concerned, that's Harley's V-Rod marketing team trying to put some sport bike spin on a technically improved (for Harley) clutch design, when the real new/different feature emphasized should be lighter clutch actuation, thanks to only 4 clutch springs instead of 5, and still dramatically improved grip, because the "GRIPPER" design will convert
at least 30% of any torque loading you hit the clutch with into
increased clutch clamping action
The HD explanatory diagram diagram Max published showed there is a 30 degree ramp/wedge action where the torque applied to the clutch is transferred to the tranny, that wedge results in the increased grip. What I cannot tell, is whether the 30 degrees is from the plane of the transfer shaft, or from the plane of the clutch disks, because one way it'll convert 30% of the torque into increased clampinh force, the other way it'll convert 60% of the torque into clamping force.. A steal at $245
