1 - 7 of 7 Posts
i just changed the bars on my RK and got everything back together and the headlight and drive lights will not work. i replaced the lamb, checking wiring, i am lost!!! Any types and Any Help would be great!
Shadow
Keep on Ridin’
It's very easy to pinch wires and blow a fuse when clamping the controls to the new bars.
Oh god.....
That's got be frustrating.
Good luck.
Might wander over to the new members and introduce yourself.
Post pictures we like pictures.
Probably just have to go back though it.....again.
Um headlight = ignition
If you didn't remove the headlight, theres no need to check behind it.
Loosen left switch assembly and move around to see if lights come on. Recheck each connector you messed with installing the bars, including the wires going into the connector. And of course, check fuses.
1 - 7 of 7 Posts
