1 - 4 of 4 Posts
I have a 02 roadking classic .. sometimes it starts and runs then after it warms up and i try to start it agian ..trys but stalls after a second or two.. after turning ign switch back on 6 flashes on the turn signal lamps and the security lamp stays on .. Im thinking a bad tssm but then what do I know thanks for any tips
Rexydog
2002 roadking
thanks ffor the reply
I have tried to read the codes but nothing matches what was in your discription.. I see a trip to the $$$$$$$$ dealer in my future
thanks
rexydog
Discussion Starter #4
found the problem it was the TSSM (turn signial safety module) located under the seat on a 2002 roadking behind the battery.. which also contains the BAS (bank angle sensor)
after install bike ran fine .. Setting it should be done by a dealer due to the clearing of old codes hope this helps someone out there
Rexydog
1 - 4 of 4 Posts
