2003 Ultra Classic with Premium Oil Cooler issue
I own a 2003 Ultra Classic with the Premium Oil Cooler added, I also have engine work as follows: 95ci, S&S G570 cams, Baker 6 speed, Power Commander, SuperSucker air intake manifold and Vance & Hines TruDuals .... My problem is changing my oil specifically the oil filter. My mechanic tells me I need either an older Sportster EVO oil filter or K&N KN-170-C filter which allows for a greater flow of oil and boosts my oil pressure, I am also running NON-synthetic oil. In order to remove the oil filter the crankcase sensor needs to be removed which is simply a pain.
Are there any recommendations pro-or-con for going back to the standard H-D oil filter 63798-99A and any idea why I have to remove the crankcase sensor before I can get the oil filter removed?
Any assistance is greatly appreciated.
Thank you,
Brett W. Sabio
Thank you,
Brett W. Sabio
