2005 Sportster Sputtering and Coughing
20K views 11 replies 6 participants last post by  hammer6315
I would check the obvious things first. Test the intake seals for leaks, could be a lean run condition. Check battery condition and cable tightness. Battery should measure 12.8v static and up to 14.5v running. The negative cable tends to loosen at the terminal on '04 and up Sportys. Also the pilot jet tends to plug up and cause a lean run condition.
