1 - 7 of 7 Posts
when ignition is turned on.... left signal comes on and when left turn signal button is pushed will not go off. The only way i can get it to go off is to push the right hand signal button. After the left turn signal stops blinking it will not work anymore.In need of some desperate help!!!!:feedback:
Addicted Since 2010
I think it is probably a problem with your turn signal module. I can't see how wiring would cause that....
If you have the service manual check the troubleshooting pages in relation to the TSM or TSSM depending on what your bike has.
Good luck, someone with more knowledge will come around eventually....
Maybe pinched wires under the clutch lever perch. Does the bike have custom grips installed ??? Then that's where I'd be looking.
1 - 7 of 7 Posts
