1 - 4 of 4 Posts
I recently got a 2006 xl1200c but it's having a problem with only one of the rear running lights.The guy I got a from broke off the left rear signal.I have replaced it and the circuit board.
But it still lights up dim but the turn signal is bright when activated.It has led bulbs in all running lights but also has a new load equalizer.
Any help would be greatly appreciated
Dim for running light. Bright for turn signal. What's the problem? Not flashing? You need a turn signal module.
If it has the module to convert turns to run\stop\turn then it is correct. But, check for a good ground. It may be trying to ground itself through the other side.
1 - 4 of 4 Posts
