I have a 2006 1200 Custom Sportster and I am attempting to completely remove the carburetor so I can rebuild it with the kit. I hit a snag though and I cannot get the throttle cables loose from the carb. I loosened up the cable cover nuts at the throttle all the way to give slack. I cannot pull the covers out from above the carburetor spindle at the bottom though. I tried using both needle nose and small flathead screwdriver to remove the ferrules (cable ends) from the spindle but all it is doing is tearing up the ends and the spindle. I also tried pushing the carburetor all the way up against the gas tank so I have lots of slack in the cable, and then tried using needle nose on the cable cover to try and pull it up out of the housing. I also attempted shoving the small flathead screwdriver vertically up into that housing (photo #4) to try and push the cable cover up and out of the housing but it won't budge. Suggestions?
For the last 3+ years or so when I slow down to stops the engine likes to die. The bike had stage 1 with screaming eagle 2 exhaust when I got the bike in 2012. After I was run over the front end was rebuilt and I put Rush slip ons but I don't think the dealer retuned the bike. I can't remember if that's when it started dying at slow speed/stops or after that. I'm hoping that the issue is the carburetor just needs to be cleaned and new seal/gasket put on and not re-tuned. At stops I either have to throttle up a little bit or reach over and hold out the choke all the way. Does it sound like the carb needs to be cleaned or retuned?
