Hey all,
I have an 07 Dyna WideGlide and it has no spark. Back story the ignition was left on and the battery died. It’s a new battery only a couple months old so I recharged it and it’s currently at 12.9V. I checked all my fuses and their ok. I have power to the coil so used an extra spark plug and found no spark. Checked the CPS and found .9 ohms resistance and 2.9V while cranking. You can smell fuel from the exhaust while cranking and you can hear the fuel pump prime when the system is turned on. I did remove the Power Commander V and still no start. Starting to think the ECM is bad. But there’s no Harley dealer close by. Not sure what else to check or do at this point.
