Sounds like they got your fuse box wet and something is shorting out. Take it home and remove battery side cover, then use a leaf blower to dry it out. If this doesn't work check for blown fuses.
The guy is a doosh.I called the dealer's store today asking about the bike,
They said the ran a check and the couldn't find anything, so they will re-check tomorrow using a computer.. When i mentioned the fuse box getting wet, the guy said it could never be the fuse box and that the mechanic would definitely have checked it.
I don't know why but i have this feeling they want to make a fuss out of it. Moreover, the mechanic i deal with usually is on vacation.
This is why i am asking, because i don't want to pay for the dealer, specially that they charge too much. Moreover, it's the 3rd day today and they can't identify my problem..The guy is a doosh.
It's a known issue with YOUR bike, enough to have Harley write a TSB.
You can take my word for it or pay the dealer.
http://www.harley-davidsonforums.co...5596-LQQKIQ-sportster-tsb-2007-xl-models.html
The first time my ignition relay went out I had to trailer it to HD shop and $112 later they replaced the relay, the second time the starter relay went I fixed it myself for less than $10 ! I liberally coated all fuses and relays with waterproof grease and haven`t had any problems since !This is why i am asking, because i don't want to pay for the dealer, specially that they charge too much. Moreover, it's the 3rd day today and they can't identify my problem..
I think i will go pick my bike up from the dealer and handle it myself.
You can always pull another realy from something else and place it in it's place to see if that relay is bad.The first time my ignition relay went out I had to trailer it to HD shop and $112 later they replaced the relay, the second time the starter relay went I fixed it myself for less than $10 ! I liberally coated all fuses and relays with waterproof grease and haven`t had any problems since !
It might pay to have an extra relay with you, and if the ignition relay fails you can switch with the starter relay and give it a push to get started.
