1 - 1 of 1 Posts
Bought a 2008 Rocker C with turn signal removed. Got led signals for front and combo led brake/turn signals for rear. Also got equalizers.
Thought putting it all together would be easy...find wiring from turn signal switches where they connect under the seat, run left front and back signals together, put equalizer between lights and switch wiring, do the same for the right side and all done.
In practice, can't find the switch wires in the harness under the seat and want to keep the wiring clean and out of sight. Does anyone see any problems with connecting front and rear signals to the equalizer and then to switch wires at the connector under the seat that led to the rear wiring? Any suggestions?
1 - 1 of 1 Posts
