1 - 5 of 5 Posts
Just finished changing out the fuel pump/regulator in Nighster fuel tank. Had spark before now no go. Swapped relays no go. ECM and fuel pump fuse good. I'm open for suggestions. Thanks
Did you check for codes ? The procedure is a DTC sticky in the electrical section.
No speedo so you'll need to use the count flashes method with a jumper wire in the data link connector. The shop can get the codes with their computer thru the data link connector too.
Reactions: WiSeNhEiMeR
Check for un-plugged wires, and measure the fuses with a meter don't just look at them.
1 - 5 of 5 Posts
