1 - 4 of 4 Posts
I have a 08 nightster, 3.3 tank, traveled about 45 miles bike speedo cut out and bike ack like it was out of fuel, checked fuel it was low, by the way I have a 2" lift on tank.. But why did speedo cut out went from 76. To 12 then back to 76
Sounds like you have an electrical problem, not a fuel problem. Check for bad wire connections, especially under your raised tank.
Addicted Since 2010
I had the same problem quite a few times on my bike. After scratching my head as it was really intermittent I finally realized that it was my hand hitting the off run switch when I would put it back on the bars if I took it off the bars for some reason....
Sometimes it is the simple stuff....just a thought.
Discussion Starter #4
I will pull tank check wiring, and watch my hand placement it could be that also never thought about that..
thanks,
1 - 4 of 4 Posts
