1 - 7 of 7 Posts
I recently bought a 1340cc harley and its in a streetbob style. I have a few issues. First when i go to start the bike it can start with the engine switch off, i followed the wires and theyre still good, is that a normal issue with harleys? Ive owned quite a few dirt bikes but this is my first harley. Second, when i first bought it was starting fine till it wasnt...only way it would start is by jumping then when i took it for a cruise it would shut off. I took out the solenoid and cleaned it. Bought a new battery and worked for a day, sat overnight and samething was happening. Could it be the starter?
Charging system is bad, got a manual?
The start switch gets its 12 volts from the run switch. Either the run switch is bad or there is a wiring failure feeding the start switch the 12 volts.
Check the battery cables at both ends- this includes the ground. It probably has nothing to do with the run switch but may be the cause of the bike cutting out.
Don't buy a starter, or anything else, until you diagnose the issue.
The cables are good. I changed my ground wire and the relay ground. I just ordered a multimeter from amazon and gonna test the battery and the stator.
Dyna's have two ground points. Neg. cable from battery to frame lug, then lug to primary case. The lug can be corroded or loose.
1 - 7 of 7 Posts
