1 - 2 of 2 Posts
So I replaced my battery it started fine the first two days.. well now I turn the key on the fuel pump turns on but when I hit the button to start it it just clicks help me trouble shoot this problem please
Sounds like a low battery...could have something draining the system, could just not be charging when running, or could be a bad battery.
I guess the first step is to test the battery itself. Charge it up and test the voltage at rest; should be at 12-12.5v. Then start the bike, and text the voltage again (that will test your charging system); at idle it should be around 13-14v. If both those check out, the battery and charging system are likely fine, and you probably have something drawing power when it shouldn't, discharging the battery while it sits.
Sent from my SM-G965U using Tapatalk
1 - 2 of 2 Posts
