So got my front end finished and need to do the “fall away” test. One side falls away at about 3”, the other side falls away immediately. How can I balance so the fall at the same distance? Newbie here 🤷🏻♂️
The tire doesn't need to be centered just in the middle of both the fall away points. Find the center and position a pointer at the middle of the fender with a piece of painters tape on the fender to make some pencil marks. Mark the center between fall away points then measure both doing the fall away test.So got my front end finished and need to do the “fall away” test. One side falls away at about 3”, the other side falls away immediately. How can I balance so the fall at the same distance? Newbie here 🤷🏻♂️
