1 - 3 of 3 Posts
I just bought a 2009
roadking police .I have an abs light on tachometer.does this means that the bike has an abs ?althought it doesn't have any teenth ring on brake disk?
All of the bikes have the same gauge clusters. Trace the front brake line down to the front disk. If it goes down to the front disk, you have no ABS. If it runs under the tank and back to the right-hand side cover, you have ABS. The ABS module is a square box under the right-hand side cover.
The current ABS design is different where it does not have a visible teeth ring at the rotor. I don't know the exact year this was changed.
If you are still unsure after following the brake lines, go out and do a hard/panic stop to see if you get pulsing rather than locking the wheel.
A quick google search indicates that the 2009 police models did have ABS.
1 - 3 of 3 Posts
