Title says it. I can’t figure out why. It only had the code once. No more code but light still on. The rear brake bulb has been changed, no difference. I went with my dmm testing rear switch. Seems I’m getting just shy of 2 volts from it without being depressed. The thing is, when I unplug both leads from the pressure switch, ie no it’s open circuit. it still doesn’t turn off, so I thought front, ordered one. Took apart today and the switch has voltage when open and drops to 0 when depressed so it’s working correctly from what i gather. So now I’m at a loss. Signals work fine everything else is as well. 2012 flstfb fatboy 38k on clock
