1 - 4 of 4 Posts
Changing rear brake pads. The kit includes some piston lube. Where does it need to be? And, What torque value does the lug nuts need to be on those rear wheels. Thanks in advance. PS: I know I need a shop manual. In that process also. Thanks again!
I'm changing brake pads and rotors on my 2013 Harley Tri glide and can't get the piston to go back far enough to go over the new pads and rotors any help I would be thankful.....
You have to remove the top from the master cylinder before pushing the pads into the caliper. If your bike has ABS then you can't do it correctly, has to be connected to the shop computer to bleed the ABS.
1 - 4 of 4 Posts
