1 - 14 of 14 Posts
I have the 4.3 but thinking of upgrading to the 6.5 that I've found on the used market. It looks like a fairly simple plug n play swap once you split the fairing. Does anyone know if it needs to be flashed by the dealer to be compatable to my bike and what would they typically charge if that were the case?
VA Fender Bender
I bet it will need a re flash
it can be done. My riding buddy bought the 14 SG instead of the SGS because he didn't want the stripes on it. He had them change a lot of the items to what the Special would have on it. Including the stereo. Not for sure of the cost to do it though.
Mine has worked fine from start,never updated. Only issue was volume would be full up on start up. Just started turning all the way down before shut down. Satisfied,honestly was afraid to update because of all the stories of problems.
Discussion Starter · #14 ·
Took it out for a ride today after installing the latest update. No issues other than the issue I had before of the music running through Bluetooth is always lower than the radio. The device volume is always all the way up.
1 - 14 of 14 Posts
