1 - 7 of 7 Posts
Hi guys,
Bought a pair of RK take off shocks (54000036 G5H3-00) to fit up to my '06 XLL.
They work great and provide a pretty smooth ride.
However, I have been guessing at the air pressure to set them at. I have been running about 10psi single and 20psi 2-up. Just wondering if there are any RK owners out there that might know what the recommended pressures are and what the max pressure for these shocks is.
Thanks.
VA Fender Bender
I will look at my service manual tonight and let you know unless someone posts the correct info before then. I run 23psi in mine solo. I weight 230
Awesome, thanks for the assist.
Service manual says about 10 psi for every 100 pounds of weight, I have mine at 20 psi when I'm riding solo and when the wife is riding it is at 35 psi, manual says with a rider 40-50 psi, to me that feels a little to high every bump feels real stiff.
VA Fender Bender
this is correct.
Discussion Starter · #7 ·
Looks like I was running them about 50% of where they needed to be.
Thanks again for the help. :)
1 - 7 of 7 Posts
