1 - 5 of 5 Posts
2022 Nightster
On previous bikes, I would use the battery tender cable to power either my phone on GPS. The 2022 Nightster disconnects power to said cable when the bike is running. I discovered that under the seat are two coax plugs for heated gear. I hooked my heated vest in both of these outlets and it worked fine. I ordered cables (make coax to sae) to run my GPS and a longer cable to power my vest. Nothing in the manual and Harley Davidson customer service knew nothing of these outlets 馃槀
21 LowRider S
Interesting. I haven't found any coax plugs on my 21 LRS.
I'll have to check if voltage is turned off with my SAE volt meter when engine is running.
I have a mantra that I repeat to myself several times a day "computers are my friend, computers are my friend...".
My own ignorance of technology frustrates me greatly, especially when the programmer has a different idea of the way something should work than I do. A few decades ago, the thought for us was that one must be a motorcycle mechanic before being a motorcycle rider. Now we have to have an electronics degree first...
Good luck with you task @SpeedDemon1693
2022 Nightster
Discussion Starter · #4 ·
Let me know if your battery tender cable has power when the bike is running for my own curiosity. I wish that I would have found the purpose of the coax plugs under the seat before I went on vacation as I had no GPS the entire time. I am still waiting to found out what size fuse for each outlet. My heated vest and GPS draw very little current so I am safe here, but I would like to know for future reference on adding additional heated gear
21 LowRider S
Remembered to check this today. My tender cable is live with the motor running. Putting out 14.4V at idle, 12.8V with motor off.
I wonder if this can be turned on/off via BCM programming at dealer.
1 - 5 of 5 Posts
