Rollers on 1 or more of the lifters.
Yup, that sounds just like mine did when a lifter roller went south.Rollers on 1 or more of the lifters.
Carbon buildup is common on TCs if run too rich. Don't forget they have piston "coolers" to keep piston temps down. Add too much fuel and carbon starts fast. Have seen this before.I just took apart my whole Top end on my 2011 Electra Glide Ultra Limited (FLHTK) with 33,000 miles because of chattering especially on cold starts. I found major carbon build up in the pistons and the valves. It's so bad some of the carbon looks fused or welded on pistons. I have Woods TW 8-6 cams - SE Stage one A/C - V&H Power Dual headers, (which had a crack before by the chamber) Monster Round slip-on's - SE Big Bore Pistons for Stock Heads and a Tuner. It did run good from Colorado to N.Y. about a 2,000 mile run.
I'm wondering if the aggressive cams and or the crack in the headers (under six speed) had something to do with the mess in my combustion chamber? Meanwhile good luck with your bike, hopefully pushrods and lifters will take care of it.
Peace!
