1 - 4 of 4 Posts
when im riding my fatboys lights will go dim and the bike losses power for a second like it wants to shut off. then the bikes lights come back and i can ride for 6 seconds and the bike goes dim again. any ideas?
Also check your regulator and connections. You may was to break out the DMM and do a quick check on your regulator and stator to make sure the charging system is working well. Check your connection from the regulator to main circuit breaker make sure it's tight and check the connection from the regulator to ground to make sure that's tight
Sounds like the main breaker is tripping. Check the headlight connector inside the nacelle, they have been known to melt causing a short.
1 - 4 of 4 Posts
