Remove the seals and toss'em. The bearings will then fall out . If you want to remove the races , I either use a diegrinder to cut one side or just use a 12'-5/16" rod to pass through the wheel and knock'em out w/BFH .
You really need to go back with new races, bearings, and seals .
